4l80e B&M Pro Ratchet issues
Has anyone experienced this and found a solution? Is there possibly another pin in the shifter I can pull so that the shifter slides further forward when going into park? Even if I have to Ratchet twice to get it in and out of park that's no big deal. Thanks for any advice.
Also on the shifter body where the cable conns. to the body, make sure the bracket on the cable is attached right-it can go inside/outside the shifter body, I forget which is correct, maybe outside.
Also you have to be in the correct hole in the trans lever.
I think I read on The Yellow Bullet that someone had problems, found out that they made a couple diff shafts for the 80E's, they clocked in diff angles, and they switched one and made a shifter work.
OK, I am out of ideas, maybe I was lucky, but used a couple of the B & Ms and they worked good-I did have to trim one a little in the shifter where it wasn't aligned perfect.
