4L80e No OD, oddly low trans temps? Any help!?!
01 1500HD with 6.0/4L80E, trans shifted perfectly fine yesterday, went to jump in this morning to head to work and it wouldn't shift into OD. 1,2,3 shifts perfect, dosnt act weird and dosnt slip. Also noticed trans temps are oddly low. Like 150-160deg tops, always hung around 210 before. Any ideas on easy things to check before I go and yank the trans??
Thanks!
Thanks!
Codes? Physically check with a scan tool.
Is 4th being commanded?
Low AFL pressure can cause a no 4th condition, But usually a drop out of 4th Hot, Low AFL pressure also affects line pressure, Are the shifts soft?
A broken 1-2 shift valve spring can also cause a no 4th condition.
I'm leaning toward a electrical malfunction because it happened suddenly with no symptoms leading up.
