4l80 questions
1. Its a 4x4 unit.
2. I'm shooting for right around 1000rwhp
I've been doing a bit of reading for the last hour on what to do and how to change the tail shaft to a 2wd unit and it seems the trans has to be taken apart to do that so it really shouldn't be an issue since I'm probably going to end up doing a rebuild, which leads me into the next issue... Since I'm looking to put 1000rwhp through it, what kind of rebuild kits should I be looking at? I have seen that just a shift kit will help it hold roughly 700-800hp on stock internals and from then on i should be looking into billet hard parts and such. Is there any kits available that would have everything I need?
As said, the 4wd units don't have the speed sensor rel., if you forget to install it, it wont shift with the controller.
