cleaning the planets
Old Aug 4, 2017 | 09:15 PM
Karlw's Avatar
Default cleaning the planets
Is there any harm in cleaning the planetary gear assembly from a 60e in mineral spirits? I'll carefully blow them dry with compressed air afterwards and then soak in transmission fluid before I store them. I just want to get the clutch material and old trans fluid off of them. I realize the trapped torrington bearing will need special attention.
Old Aug 8, 2017 | 02:49 PM
Karlw's Avatar
Did I ask a stuipid/obvious question here?
Old Aug 8, 2017 | 06:56 PM
clinebarger's Avatar
No harm in what you propose, I use a Siphon Blow-Gun that siphons from a bucket full of clean solvent to clean carriers, valve body, & other parts I don't like running through the parts washer.
