4L80E Yoke Engagement
little engagement
I had an 1 1/4" inside the seal while I had a 2 1/8" outside the seal. I understand that is not enough engagement, and I think I am going to have PST build me a new shaft. My question is how much yoke should be inside the seal on a 4L80?
Also, since I won't be needing my old shaft, is there a market for used drive shafts. I don't hardly want anything for it just curious. Thanks for your help.
If the Output Shaft is fully splined, You can run a pretty long yolk.
You can just install a longer yolk if you want, Sonnax yolks are very nice & balanced......Of coarse if your yolk is out of balance & the shaft was balanced to compensate, You will need to re-balance the shaft.
I would do it the right way and use a counterbored yoke.
80e on top, 60e on bottom, both forged PST yokes
Counter bore for the oring. Now if his is like that, imagine how LITTLE splines he has engaged in its current configuration, and that counterbore aint doing jack ****.
It's based off years of experience. Not just my own but thousands of customers too.
A cut off yoke or a non counterbored one will bottom out BEFORE it even gets to the oring.
Your advice will cause damage.
I wouldn't base my measurements off the oring location.
We machine output shafts to prevent this issue, that's the ideal scenario. However a real counterbored yoke is the solution in this case.
