Th400 crossmember
Old Sep 11, 2017 | 08:27 PM
stock ta's Avatar
Default Th400 crossmember
Which is the best crossmember to get when putting a th400 in an 02 trans am. I would like something that bolts on and doesn't have to be shimmed or use a 1 inch block.
Old Sep 12, 2017 | 01:59 PM
jimmyp3353's Avatar
This is the one I use. No problems at all, fit great.
http://www.tickperformance.com/umi-9...ion-kit-th400/
Old Sep 12, 2017 | 02:17 PM
jrpimp00's Avatar
Depends on your torque arm situation. I used a BMR onr like the one below but I have a short torque arm which has an integrated DS loop
https://www.summitracing.com/parts/b...r/applications
http://www.tickperformance.com/umi-9...smember-th400/
Old Sep 13, 2017 | 08:48 AM
stock ta's Avatar
Great thanks, I have the Spohn chassis mount short torque arm with driveshaft loop. I am currently using stock M6 crossmember with the Spohn spacer. I think it has my trans up to high. I want to switch to a crossmember that will bolt in and not have to use any spacers
Old Sep 14, 2017 | 11:10 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
We use BMR in all of our TH400 swap kits.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Sep 18, 2017 | 07:03 AM
conexion914's Avatar
BMR here as well.
Old Sep 18, 2017 | 07:29 PM
BOLO's Avatar
I'm having a Th400 built and I went with Midwest Chassis Th400 cross member.
