4L60E shift solenoid replacement as regular maintenance?
Old Sep 11, 2017 | 09:07 PM
Steve L.'s Avatar
Default 4L60E shift solenoid replacement as regular maintenance?
I will be changing the fluid and filter in my aging 4L60E in the near future and I'm soliciting opinions here on whether any of you replace the 1-2 shift solenoid as a maintenance item or only when they are causing problems? The solenoids appear inexpensive, and easily replaced with the pan removed. Thanks
Old Sep 11, 2017 | 10:52 PM
clinebarger's Avatar
Don't fix what's not Broken!
Old Sep 12, 2017 | 08:46 PM
performabuilt's Avatar
LS1Tech Sponsor
Agreed if you do not have a problem don't fix it , Many times fixes like that result in a problem.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
