Help! Smoked 4L70E Post-mortem Analysis (W/pics)
I stopped driving the truck after about 300 or so miles on it. Checked the pan again, alotttt of clutch and bushing in the pan. I parked the truck and tore the trans down.
Here are the results...
So my main question is, assuming that the loss of trans fluid was the ultimate cause of the clutch failure. Why would that be the only clutch pack with damage. All other clutch packs looked brand new. What else could cause that damage besides low fluid?
tailshaft bushing is also heavily worn. Both into the babbit
During the rebuild, i replaced both of these. I remember when installing the torque converter, it felt really tight... but i assumed thats just because its a brand new converter and brand new bushing. Whats the clearance spec on that?
i feel like maybe the bushing and or converter hub were not correctly sized???
I installed the bushings with a driver, so id assume they were installed straight.
I would replace that Input Drum as cheap as they are from GM. ($125)
The case bushing wear could be from the T-Case adapter cracking & causing the output shaft to run off center.
The pump bushing should be removed & reinstalled from the PUMP POCKET as there is a small lip to prevent bushing walk-out. If you beat it in from the SEAL SIDE.....The converter hub will be tight on the bushing, There will be aluminum debris under the bushing, The bushing will be distorted.
100% check the bushing on the converter hub before assembling the pump.
Beating bushing in with a hammer is a poor practice in my opinion.....Use a Arbor Press!
At idle with no load.....You should have around 75-80 psi (Depending on the PR Spring) & 230-240 psi at full EPC/Torque signal boost (Depending on Boost Valve)
Is a new drum really necessary? Its a DD, not a racer.
why would i only totally destroy one friction?
I had a sonnax boost valve and whatever shift kit that came in my rebuild kit.
TCI kit that contains Raybestos BPZs
I dont remember the clutch clearance, but i did set it to the spec they recommended (i think it was something like .008" per disk???)
what causes the drum to get beat up like that?
the reason i ask all these questions is to simply better my education on automatics
If you can feel ANY harmonics in the truck with the TCC engaged.....It's real bad in the trans!
You can try to smooth the lugs out a little with some emroy cloth, But I would replace it, Make sure the 3-4 steels are indexed correctly also.
Also, i had a random missfire from a bad o2, and you could feel it BAD when the converter was locked up.
So would the banging 1-2 shift have nothing to do with the drum damage?
