4l60e servo valve delete
Old Oct 2, 2017 | 03:43 PM
sefi's Avatar
Default 4l60e servo valve delete
hi
i`ve seen some builders who thakes out the original one-way valve, and install a plug instaed.
is that correct?
and should i install the plug before the 3-4 oil gets into the 2nd accumulator, or install it underneath?
thanks
Old Oct 2, 2017 | 06:32 PM
clinebarger's Avatar
I personally never do this, But it seems to work.
Install the plug 'til it bottoms in the case. It can cause a soft 3rd apply on the first 2-3 shift of the day.
If you block the 3rd accumulator.....The band will not release on the 2-3 shift!
Why are you interested in doing this? If you have some leakage at the capsule....Take a flat nosed punch & re-seat the checkball with a few light taps.
Old Oct 3, 2017 | 03:53 PM
performabuilt's Avatar
LS1Tech Sponsor
I also do not suggest doing this mod for the reasons listed above.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 5, 2017 | 02:28 PM
PBA's Avatar
PBA
Same here! Leave it alone... Only replace with another one, it if it cannot be saved (rare) from the above suggestion.
Old Oct 5, 2017 | 02:45 PM
coryforsenate's Avatar
Unanimity between three expert builders seems pretty clear.
