tci outlaw shifter noob
just started looking into these and cant find anything on if installed do you always have to manually shift now or is there still an equivalent "drive" to put it into and let the car shift itself if you want perfect shifts or just being lazy
it will be installed on a 4l60e if it makes a difference
do all gated shifters like the tci outlaw eliminate the computer completely? if so do they shorten the life of the trans at all I'd assume no but don't know much of anything about these
so if you put the car in what would be 4th with the tci and take off the car will still start itself in 1st and cycle through the gears itself? because I feel like looking at everything the tci or hurst quarter stick etc you always have to shift the gears.
