Launching question
Old Oct 14, 2017 | 01:14 PM
Sladester2's Avatar
Default Launching question
Anyone know what would cause a a4 with a Yank ss 4000 to shift into second almost directly after the converter flashes? This only happens every 1 in 4 runs or so.. Once it goes into second it stays there, won't go into third by itself.. Usually cut 1.5 60fts but when this happens it cuts 1.7s? Please help. If I try to manually shift it into third on the return road it still doesn't go into a different fear.. Only if I put it into neutral first then it will shift again
Old Oct 14, 2017 | 03:59 PM
bbond105's Avatar
Which trans is it. 4L60E, 4L80E or some other?
Old Oct 14, 2017 | 04:51 PM
Sladester2's Avatar
L60e, if I put my car in neutral after the burnout, then back into drive, it will leave fine
Old Oct 14, 2017 | 08:16 PM
bbond105's Avatar
Do you have HPTuners on some other way to log your pass? It would be very helpful if we could see if the shift was being commanded. You could check the TPS.
Old Oct 14, 2017 | 08:30 PM
Sladester2's Avatar
I will have to get my tuner to get a log next time I'm out and thanks I was thinking possibly tps tricking my car
Old Dec 4, 2017 | 05:25 PM
Sladester2's Avatar
Still happening, got stuck in second again.. Unplugged and plugged back in tps and I had first but I'm hoping it's not a coincidence.. Also hoping it isn't limp home mode but I have no transmission codes so idk
