I have no 3rd gear
Old Nov 3, 2017 | 12:16 AM
oscar1212's Avatar
Default I have no 3rd gear
I have a 95 chevy c1500 rwd and was shifting fine parked it for about an hr and now no third gear acts like its in neutral. all fuses are fine.
Old Nov 5, 2017 | 01:31 PM
performabuilt's Avatar
LS1Tech Sponsor
If it shift 1-2 then when should shift to 3rd goes to neutral (Actually 1st) but would feel like neutral something had happened to the 3-4 clutch, Snap ring broke out, clutch failure something is that nature and yes it can happen suddenly it is not an electrical issue , Time for a rebuild or a trans.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 8, 2017 | 08:35 PM
mrvedit's Avatar
Moderator
Yup, the loss of 3rd and 4th gear is probably the most commonly reported problem here.
The '95 year is also an odd-ball unique year; if you decide to replace the trans, you will need another '95; other years will not work properly.
