Shift kit actually worth it?
The former owner of my girlfriend's son's Z28 put a B&M shift kit in the car and it's horrible for a daily driver. It kicks like a mule 1st to 2nd gear.
A friend has a Transgo kit in his TA and it's better than the B&M in my opinion in all regards.
When my 72 vette got the TH400 transmission rebuilt in 2009, I picked up the internet recommend Transgo shift kit. The shop took one look at the box and said no way are we using that kit. We've been doing this for 35 years and have our own kit that's better in every way. I asked about the B&M kit. Trust us on this you don't want either one of them but the Trans go sucks less than the B&M sucks. They were dead on the money. The TH-400 is crisp shifting without been annoying. The transmission shop had an excellent reputation locally and delivered.
Back in 2008 I went through the same discussion about the 4L60e with the shop whenI was getting the 4L60 rebuilt.
This is my experience with shift kits. Both of the custom kits the shop did I like.
None of the off the shelf B&M or Transco kits I've experienced driving or as a passenger were as ideal as the custom kit from the transmission shop.
The Transgo shift kit is really popular too. I don't think you can go wrong with either one.
As youngengines mentioned, firmer shifts will lengthen the clutch life span.
With a smaller aftermarket converter, a shift kit is a must for me. First of all, the tranny's coming out of the car in any case. Firm up the mushy shifts, get better oiling throughout the unit, and eliminate PWM which could compromise clutch life. Plus various valves, springs, and odds and ends that make for better performance and longevity.
Making the 1-2 shift too firm not only is unpleasant to the driver, but it can break internal parts, u-joints, etc. For this reason the B&M shift kit should never be used, and if already installed, should be removed.
Even if a full shift kit is not installed, I recommend installing at least a bigger boost valve such as the .490" Sonnax 4l60E-LB1 (or LB2 for ISS units). As mentioned, a shift kit helps a trans life longer under performance conditions by reducing slippage (and wear) during shifts. Also, the complicated 3/4 clutch circuit over time tends to start leaking a bit in any number of places, and drilling the separator plate's 3/4 feed hole bigger helps provide enough volume to overcome small leaks.
These are just a few reasons why a shift kit is worthwhile.
The kicker is that you can crank up the programmed pressures and shift speeds in the tune and that will only net you what the stock components are capable of delivering. Alternatively by reprograming the mechanical aspects of the transmission you can overcome some of these limitations - basically making the transmission more analogue in the process - with a "shift kit"; plus you can make it function differently with specialized parts (like the HD 2-3 shift valve from Sonnax).
At the end of the day you should do both a shift kit (or kits + other components) and tune the transmission to get the performance you desire/require. Tuning it properly will require datalogging the commanded vs. actual pressures using a pressure transducer, and the calculated vs. delivered torque - it really is a multifaceted approach. At the end of the day all of this PWM stuff was added for comfort and reliability (in the sense that the TCM could compensate for irregular or changing conditions (such as temperature or load)).
tuning takes care of the first, mechanical means takes care of the second.
