Noise coming from Flexplate
Old Jan 31, 2018 | 08:43 AM
Rezorector's Avatar
I checked all of the bolt lengths, they are not bottoming out or binding. I took the old flexplate off and inspected it and found nothing. Got the new flexplate installed and trans back on, going to get everything else bolted back up this evening and start it up and see what happens. I am going to start it up without the converter bolted to the flexplate just to make sure i dont hear the sound at that point.
Old Feb 3, 2018 | 03:48 PM
Rezorector's Avatar
Well i finally got everything put back together. I started the car up without the converter bolted up and there was no noises. Then when i bolted the converter up i got a noise. Its not the same noise as last time heh. I have attacked 2 videos. First one car is in neutral with light reving. Second one is car in park.
In Park
Old Feb 3, 2018 | 04:02 PM
Texas Patriot's Avatar
Sounds like something is rattling around inside the converter. Could be many different things but I think its obvious the converter is the problem.
Old Feb 3, 2018 | 04:08 PM
Rezorector's Avatar
That is possible. I did spin the converter around like the guy in that video but i did not hear anything like that.
Old Feb 3, 2018 | 04:20 PM
Do you have an extra stock converter you can throw in there? I bet the inside of the converter has something inside it and the fins inside are hitting it.
Old Feb 3, 2018 | 04:38 PM
Rezorector's Avatar
I do not have another converter at this time. Guess ill start shopping around for one.
It does bug me that after changing the flexplate the sound is different.
Old Feb 5, 2018 | 09:03 PM
Rezorector's Avatar
Well i decided to put a 1/64th size shim on the starter just to try it. And what do you know the noise is now gone, i shifted through all of the gears and reved it a little and heard nothing.
Old Feb 5, 2018 | 11:17 PM
tug686spd's Avatar
Glad you found it. Was there any marks on the nose cone?
Old Feb 6, 2018 | 08:20 AM
Rezorector's Avatar
I did not see any obvious marks. I could have easily missed something though.
