Ford/ZF 6R80 behind a LS3?
Anyone got anything on this?
I do know that we have PLENTY of 6R80 guys pushing 1200+ through there 6R80s with just some clutch pack upgrades and a billet input shaft and a billet torque converter. There are also a couple stand alone controllers for the transmission that will cover that aspect for you.
-Dalton
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Given the amount of design and fabrication already put into the car it would be nice for a change to be able to get a bolt up kit, by all reports the 6R family are great autos far more suitable for my application than a 4L.
Worth an ask here though, no problem, I'll continue putting the pieces together. Anyone know of a stand alone controller for the 6R?
Anyone know anything about them?
Where you are referencing Mustangs getting LS swaps more commonly that is mainly happening in older Fox and SN95 bodies which would require custom fabrication to fit the motor and the transmission in either scenario. The difference is the 6L80 bolts right up to the LS and can be upgraded to handle the abuse and the 6R80 does not bolt right up but can also be upgraded to handle the abuse.
1-866-726-8358
FTIPerformance.com
-LS engines are offered with a GM 6L80E Transmission.
-Both the Ford 6R80 and GM 6L80E are the same Transmission (ZF 6HP Based) except for the case, bell-housing, pump, and valve-body/ TCM.
Why use the same transmission (6R80); but with a Ford bell-housing and an adapter plate, flex-plate, torque-converter, Etc...
When a direct fit (6L80E) transmission is already available???
1-866-726-8358
FTIPerformance.com
