Cracked transmission case!
Driveshaft too long?
It would be cheaper for me to just buy a case and swap it out. Can you do that kind of work?
I can buy a whole core for $40.
The problem with that question is, what condition is your transmission in? VS buy a whole other one and swap it in having never seen the inside.
If you swap your case you might end up with a rebuild but a good trans in the end.
If you buy used you end up with a mystery that might need a rebuild.
