trans assembly lube
Have been reading posts for a while and think im nearly ready to attempt my 1st 4L60e rebuild
My problem is in New Zealand none of the local shops stock trans assembly lube say to just use engine assembly lube, is this ok or would petroleum jelly work better. Have trans mounted on a engine stand and was also going to put some fluid in and rotate when all done to ensure everything covered in fluid (including floor)
4l60e not as common over here and parts are expensive.would just like to thank the guys that freely give out there years of knowledge and time to help us 1st timers.
Cheers NZLS1
I would highly recommend some SPX-Filtran TransJel!!!
literally cant afford to get it wrong and have it fail.
