TCC pwm
Old Feb 26, 2018 | 01:24 PM
MaroonMonsterLS1's Avatar
Default TCC pwm
Does anyone know what frequency the tcc pwm solenoid pulses at?
Has anyone scoped it with an oscilloscope possibly?
Old Feb 26, 2018 | 06:24 PM
clinebarger's Avatar
32Hz....
Old Feb 26, 2018 | 09:43 PM
coryforsenate's Avatar
Out of curiosity, why do you want to know what frequency the tcc pwm solenoid pulses at? Some sort of interesting mod or troubleshooting?
Old Feb 26, 2018 | 10:56 PM
kingtal0n's Avatar
its an on/off pulse not a sine or triangle or anything weird. If you put 99% in the software I assume it means 99/100 of the time it is found to be "ON". which is pretty much just on all the time, like a switch.
Thats how most people say they program the TCC. However I still prefer some less % minimum at least to reduce drivetrain shock at low loads. It is a tunable feature. So again i assume 75% is 75/100 of the time, pulse is "ON".
Old Feb 27, 2018 | 02:25 PM
That's the duty cycle not the frequency. I've done some deep reading and I *think* it's 32Hz
I want to use the tcc solenoid control as a trigger to a solid state relay. Essientially use the stock pcm as a nitrous controller.
Since pcm can only do lockup in 2nd gear and on, it would probably be for a 2nd stage. I wish it could lockup in 1st.
Old Feb 27, 2018 | 06:14 PM
It is 32Hz.....I've "scoped" it, I guess you missed my earlier reply.
Old Feb 27, 2018 | 07:14 PM
I was looking at it on mobile and totally missed your reply! Thanks!
Is there any vehichle with a 4l60e that has the availability to lockup in 1st? Would be worth the segment swap if so...i strongly doubt it tho
Old Feb 27, 2018 | 08:17 PM
Not that I'm aware of.
Old Feb 27, 2018 | 09:43 PM
kingtal0n's Avatar
If I turn something completely on and then completely off 32 times per second but for 99 percent of the time it is on, because the shape is a pulse there is no need to find area under the curve since it is always "on" 100%.
The unit is simply "on" for those pulse periods approaching 99/100 of the time, whether it is 1 time per second or 32 times per second.
Do you mean you wish to cycle a solenoid with TCC pwm output? It goes against the computer's thinking of 'locking up' when there is a reduced throttle position. In my HPtuners the release feature doesn't work at all. Furthermore the behavior of 0% minimum release is intermittent. I would call it extremely risky to let this finiky output play with nitrous. Not my gen3 411 ECU anyways. IMO this is a bunch of unnecessary bs and the wrong way to do nitrous. It should be activated through a combination map and tps, through a progressive controller. You want to play with electronics, write the digital arduino code to control the solenoids from your own board and design the solenoid driver as an external upgradable. It doesn't take much hardware, you can buy almost any IC you need now for pennies.
Old Mar 16, 2018 | 08:33 PM
rpturbo's Avatar
I am not going to say anything negative about trying and learning but I can't argue about trying to use Arduino. I know that someone is now using this as a boost control to pulse a solenoid.
Old Mar 16, 2018 | 09:37 PM
kingtal0n's Avatar
A digital processor allows a user to program detailed instructions, outputs for different situations. Traction control for example, using ABS sensor data.
