4l70e to 4l60e
Old Mar 8, 2018 | 11:05 PM
Jonathan Mayhew's Avatar
Default 4l70e to 4l60e
Hey I have a 2008 gmc sierra vortecmax with a 4l70e. The 4l70e did not hold up. I have a built 4l60e from a 1998 gmc sierra I'd be looking to swap. What is needed to be done to actually make it work.
Old Mar 9, 2018 | 11:01 AM
06GR's Avatar
A 4L70E is a built 4L60E. What happened to the 70E?
I believe the 08s had an ISS (speed sensor) in the trans, so a direct swap isn't an option. I think you can tune around it, but some other guys with more experience will have to comment on that.
Old Mar 9, 2018 | 01:21 PM
70e couldn't handle a built 6.0l
Old Mar 9, 2018 | 01:22 PM
Originally Posted by Jays_SSZ28
I wouldn't do it. the '98, if you're sure of the year, will not even bolt up properly.
And the Input Speed Sensor, well you need it and it won't retrofit back to the 1998 transmission.
your saying even if I tuned it it will not work. I know it bolts up no problem
Old Mar 9, 2018 | 05:34 PM
If you think it'll work, then go for it.
Not sure how you plan to tune in an input speed sensor thats not there.
done. Truck works great shifts ******* hard just how I Remember that trans. Bolted up and all. Had to computer tune solo it could find 3 and 4th but just wetn 232 in her thanks all
06GR's Avatar
Jay, I thought you could tune it out?
Old Mar 12, 2018 | 01:51 AM
Not sure this thread had a point.
Most people ask questions for projects they never do or have someone else do.
That sure was fast.
This is why I don't ask questions, if I think it's going to work I just do it.
needed to get a new trans in. A couple days later and it works ******* amazing. Having fuel issues now. But I smell fuel and truck has lately been getting sluggish and found fuel pump not doing it' prime soo.ill put one in.
Old Mar 12, 2018 | 10:09 AM
06GR's Avatar
That sure was fast.
What's the torque spec for my oil drain plug so I can tell Speedy Lube when I take it in?
