need a 60e pump interchange expert
Old Mar 12, 2018 | 07:42 PM
gonzo 6.2's Avatar
Default need a 60e pump interchange expert
Broken pump gears 04 trailblazer 4.2L has no oring style 24206611 stator side 24201073 pump
I have a good 07 5.3 pump,stator side 24230672 with ISS hole and plastic plug the pump is 24201073.
Should I be able to use the 07 pump 24201073 ? And I have a good used stator side ending in 705,it has the short stator,so I could press out the 04 300mm stator and install in the 705 . Should this work? anyone have a list/link of pumps and a break down and comparisons? thanks
