Other Parts?????
Not a trailblazer ss either, those have stock stall speeds.
So is there a particular brand of rebuild kit I should buy for the Corvette Servo? and I am assuming I should purchase GM solenoids and internal harness?
I bought the Trutech Kit I mentioned in my previous post.
I just want to Thank ALL of you for your assistance.
The electronics are all either BWD or ACDelco when they arrive. Solenoids, both the shift noids and the pwm noids, pressure switch, epc, harness/plug. It's all there.
As far as the trutech kit it looks good. I can't see from the description which thickness friction/steel comes with the GPZ setup for the 3/4's. If it has .060/.065 clutches, I would spend the 30 bucks and just buy different BW high energy clutches) if they're .080 then they're just fine to use
I usually like either of these setup for the 7 clutch 3/4's depending on which pressure plate you have:
If you have the .157 pressure plate:
.093 snap
.157 pressure
7x.080 clutch
2x.095 steel
4x.076 steel
.223 apply
Total stack=1.527 (roughly 35 clearance)
if you have the .190/.192 (referred to differently depending on the supplier) pressure:
.093 snap
.192 pressure
7x.080 clutch
6x.076 steel
.223 apply
total stack=1.524 (roughly 35 clearance)
This equals about .005 clearance per friction. You might have to juggle steels to get the right clearance.
Make sure to always put thicker steels in the middle of the pack as a heat sink during apply. I actually prefer the .157 stack but there's nothing wrong with either of them.
MaroonMonsterLS1 I appreciate all your input and it makes perfect sense to me however I'm not doing the build myself, I have an ex GM trans guy doing my build. I am however purchasing all of the parts and that is the reason for all of my questions, I don't normally buy junk for my cars.
If the guy you have building yours happens to still have a commercial account, have him check into the kit for you.
https://www.ebay.com/itm/4L60E-Trans...53.m1438.l2649
He says 2 weeks. I trust this guy because he does work on my Corvette when there is anything too big for me to do myself, Great Mechanic. A stock 4l60e combined with stock transmission tune is really just........MUSH! lol
