Trans builders/experts 4l60E burnout
Old Apr 15, 2018 | 06:41 AM
Dwalt79's Avatar
Default Trans builders/experts 4l60E burnout
Wanting people to weigh in on burn out procedure at the track for the 4l60E to minimize chance of breakage
I've done a Lot of searching and seems a wide range for what people do lol
I've seen over and over with th400 guys that you don't want to shift 1-2 during burn out...does this apply for the same reasoning to the 60 e?
Old Apr 15, 2018 | 06:47 AM
98CayenneT/A's Avatar
The 4l60e is completely different than the th400 so no that issue does not apply to 4l60e.
Is this a stock 4l60e?
Old Apr 15, 2018 | 07:09 AM
Dwalt79's Avatar
It has been built but came with the car so I can't confirm what was actually done to it
Old Apr 15, 2018 | 07:35 AM
MaroonMonsterLS1's Avatar
The reason a th350 or th400 need a special burnout procedure is that on the 1-2 shift it shocks the hell out of the intermediate sprag. Theres also alot of force on the sprag when the tires bite at the end of the burnout. The 4l60e doesn't operate in the same way.
A 1-2 shift is going to bring on the band and other than heat, I see no big issue doing that on a 60e.
I personally start in 1, shift into 2nd and roll out from there.
You can shift into 3rd if you want then rollout...or shift into 3rd right as you're rolling out. But I see no need to build up heat in the 3/4 clutches by bringing them on during a burnout. But if you want to I don't think it's going to hurt
Old Apr 15, 2018 | 07:41 AM
Dwalt79's Avatar
That's been my procedure so far...start in 1st shift to second 4-5k then finish in 2nd and ease out trying not to let the tires bite
Old Apr 15, 2018 | 10:12 AM
01ssreda4's Avatar
There is a burnout thread in the drag racing section, check it out.
