Bellhousing to block cover plate?
Old Apr 25, 2018 | 01:58 PM
Sunbeam Fanatic's Avatar
Default Bellhousing to block cover plate?
Hi All,
Apologies for the amateur question but now my TH400 is fitted to my LQ4 there is of course the gap at the bottom of the bellhousing that you can see the bottom of the Torque Converter through.
My question is, where can I buy a cover plate for this gap which will stop debris getting into the bellhousing?
Many thanks.
Old Apr 25, 2018 | 02:04 PM
Jays_SSZ28's Avatar
https://www.ebay.com/itm/GM-4L80E-To...ha20jV&vxp=mtr
This will only properly bolt to a th400 with the big bolt holes on the angled sides, not the little dust cover bolt holes. If the bolt bosses are big enough you can drill and tap them. The best part is it is a factory part that bolts to the engine like a stock application with a 4L80E.
