First Th400 build and of course I have questions
Old Mar 20, 2018 | 10:27 PM
ringgold's Avatar
Default First Th400 build and of course I have questions
As stated, I'm building my first TH400. I've got the Cliff Ruggles manual and the ATSG manual. I've also read a bunch online. So here is what I have found out so far about my particular transmission.
I paid $100 for it originally, was told it came from a truck, appears to be a 1979 model trans. It doesn't have an output shaft housing on it, so I'll need one of those. Was also told that it didn't have reverse. Upon tear down I noticed some sort of material through out the trans and it appears that it came from the reverse band. This trans has the rough finish drum and it appears that a smooth reverse band was installed at some point and I assume that's probably why the trans lost reverse? The band was loosing a bunch of its friction material. All of the clutch packs looks pretty good and nothing looks burnt there. The low roller clutch fell apart when I removed it, a bunch of the rollers fell out, that'll be replaced. I measured all of the bushings and adjacent surfaces that ride in the bushings. Seems I'll be replacing those, here is what I found for clearances:
Main shaft to sun gear shaft clearances = .0062" - .0075"
Pump stator shaft bushings (front and rear) = .0073" - .0151"
Main shaft ring gear to output shaft bushing = .0131"
Reaction carrier bushing to center support = .0068"
Center support bushing to sun gear shaft outer = .003"
Case bushing to output shaft = .0043"
Output carrier pinion = .022"
Reaction carrier pinion = .015"
I plan on following info found in this forum especially cameronvic's build thread and from http://www.crankshaftcoalition.com/wiki/TH400
http://www.ckperformance.com/Tech-Bl...gCategoryID/62
The trans will be going behind your run of the mill 6.0 LS turbo engine. If I had to guess it will make between 600-800whp on E85. I do not plan on putting a trans brake on it right now and plan on just modifying the stock VB.
I have some questions about a few of these parts.
Aluminum apply pistons, are these the correct parts?
https://www.ebay.com/itm/332583972931
https://www.ebay.com/itm/152788725936
4L80E direct drum and sprag
Aluminum VB accumulator piston
Torrington rear case bearing
https://www.ebay.com/itm/141923630914
Also, I'm unsure if I need a different output shaft or if the one that came in my trans will work. I think I have to change that and get the correct housing.
Other than normal wear and tear parts that would be changed in a rebuild such as case seals and lip seals, frictions and steels, bushings, etc is there anything else I should look into? Am I going in the right direction or missing anything? I've looked at those master rebuild kits and they either have more than I'll need to replace or don't have everything I want, so it looks like I'll be sourcing the stuff individually.
Old Mar 20, 2018 | 10:38 PM
pdxmotorhead's Avatar
For me,, I'm all about doing it once..
Doesn't matter if its a transmission , engine, whatever,, I put all new seals on anything that gets opened up, new gaskets, and I use Aviation sealers where applicable. I had to re-pull an engine once due to not replacing a 10 dollar seal.. Never again.. (Isuzu trooper death of a thousand cuts)
Sounds to me like you've mapped it out pretty well, Keep everything clean, use ATF on any seal and pre-soak the clutch packs/bands any friction part in ATF before assembly.
Gonna watch how it goes!
Old Mar 20, 2018 | 10:44 PM
ringgold's Avatar
At one point in my life I was an aviation mechanic (USAF) so I'm all about doing it correct and not having to deal with taking it all back apart.
I just have some questions about the parts I listed that I'd like to install during this rebuild and if I'll need to be tracking down the correct output shaft and housing, which I think I will be. I've been reading a lot about these things for a couple weeks now and I get lost in some of the information I find sometimes.
Old Mar 20, 2018 | 11:00 PM
I know how you feel, I'm in the middle of sorting how a 6L80 and 8L80 series work... I'm planning on a Ly+6l80 in my Jeep cause I want the gear splits and the highway performance. So I'm hoping to add telemetry to the trans so I can compare the tune to the solenoid behavior.
One of the tranny build threads on here has a really good blow by blow on some TH400 parts choices but my search fu is weak tonight.. I'm more of a off-road 4x4 guy so I havn't dug in to drag tranny strength tricks.. I've always just used a commercial truck/bus rebuild kit(s) and I have a buddy that used to be a line rebuilder so he knows the assembly tricks..
Old Mar 21, 2018 | 11:43 AM
ringgold's Avatar
Can someone tell me if these are at least the upgrade to the steel pistons that were in the trans?
Old Mar 21, 2018 | 03:01 PM
Game ova's Avatar
Yes, the aluminum pistons are what you want. Price seems insane though.
Old Mar 21, 2018 | 04:29 PM
ringgold's Avatar
Know of anywhere I can get some at a better price?
Old Mar 21, 2018 | 04:33 PM
Game ova's Avatar
I don't. But you can probably find a whole core for about what they are asking.
Old Mar 21, 2018 | 05:23 PM
98CayenneT/A's Avatar
https://www.wittrans.com/parts
Old Mar 21, 2018 | 05:28 PM
https://globaltransmissionparts.com/
Old Mar 21, 2018 | 09:16 PM
ringgold's Avatar
Originally Posted by 98CayenneT/A
3rd time in a few days I've seen that site pop up in a recommendation. I'll check them out.
Old Mar 21, 2018 | 09:22 PM
Great place, I have one local so it's nice I can just stop in there.
Old Mar 22, 2018 | 08:31 PM
ringgold's Avatar
So I just ordered the aluminum apply pistons and the 80e direct with sprag. So that's out of the way for now.
Old Apr 7, 2018 | 11:37 AM
john kilgore's Avatar
Default parts
send me a list of hard parts you need, pay the freight no charge one time
Old Apr 7, 2018 | 11:43 AM
how can you beat FREE!!!
Old Apr 12, 2018 | 04:39 PM
lf free is not good, how much do you charge me to give you parts
Old Apr 17, 2018 | 11:13 PM
ringgold's Avatar
Thanks for the generosity, but I think I have everything for it right now.
Old Apr 25, 2018 | 06:04 PM
that's a 4x4 out put shaft
