noise manually downshifting 4L60E
Old May 9, 2018 | 06:45 AM
pwgr71's Avatar
Default noise manually downshifting 4L60E
I have a 93 Sonoma (4.3L) with a rebuilt 4L60E trans with about 20K on it. Sometimes i manually downshift if from OD to D if the engine is lugging in the low 40 mph's. As far as i know this is not bad for it but it's now making a noise when i do it... mostly a clunk. Wondering what the problem could be. It's still under warranty, so when i call i'd like to know more about what i'm talking about. Thank you in advance! I plan to check my u-joints to see if they're ok.
Old May 9, 2018 | 07:11 AM
fst100's Avatar
i'd check the trans mount if it hasn't been replaced as well as motor mounts, u-joint, suspension related components.
Old May 9, 2018 | 07:46 AM
pwgr71's Avatar
Thanks, that was extremely quick! I’ll post back if/when I figure anything out.
Old Jun 9, 2018 | 06:10 PM
pwgr71's Avatar
Now what happens when i downshift from OD to D is absolutely nothing. Anyone know what went to hell in it? Thanks!
