Rebuilt 4l80e blows front pump seal.
I'm hoping I can get away with just changing the clutches and steels...no bushings, seals, or hard to install parts.
Your statement " I'm hoping I can get away with just changing the clutches and steels...no bushings, seals, or hard to install parts" is possible but in no way practical, or prudent. If you have the trans out, now is the exact, perfect, time to replace bushings, seals, and anything else that needs attention. Cutting corners while you have it out now will mean you may get to pull it a 2nd time in the near future.. Do it once, do it right.
When you get it apart inspect the internal diameter of the direct drum where the center support sealing rings ride. Any damage inside that drum IS going to be a problem later. At my shop we will only install the 1 piece (non scarf-cut) teflon sealing rings. We will NEVER use the factory hard plastic sealing rings under any circumstances. If you find your direct drum has grooves cut inside where the rings ride, you can purchase a new drum, or have the drum machined and a Sonnax bushing pressed in that restores sealing ring mating surface integrity. We machine our drums in house and put the bushing in. Also, if there are grooves in the direct drum, inspect the sealing ring grooves on the center support for wear and/or damage as well. If the ring lands have contacted the inside of the drum due to worn bushings, you may find that the sealing rings will bind in the grooves. This is a big problem that will necessitate a rebuild very shortly if you miss it. Also, the BIGGEST problem that we see with 80E's is loss of reverse..... So, while you have it apart-replace the reverse band!
I know you said it was rebuilt <9K miles ago, but I would not trust in anything anybody has told me unless I was there to witness it myself. What you have been told may, or may not, be true. Once you get it out, YOU need to visually inspect it all yourself, or take it to someone who is knowledgeable on these units, and have it gone through again. Also, do not forget to check for the presence, and condition of, the dowel pins on the back of the motor. Missing, or pins that are pressed too far into the block will cause rapid pump wear, destruction of the torque converter neck, and failure of the pump bushing and/or seal.. The dowel pins are another area people rarely think about until it destroys a pump, and takes the trans out with it. PLEASE post back and let us know if you tear it down. I will support you in any way that I can. Pics are AWESOME for other people who want to learn about these units.
There is some damage to the converter neck, it has a deep scratch all the way around it near the base. Front seal seems to have a little lip cut out of it too. Looks like I need to decide if I can tackle the rebuild or take it to a local shop.
Did an LS swap with 4l80e in my Silverado. Got a donor trans from a 1996 C2500 with 81k miles. Before I swapped it in, I changed all the external seals (extension housing, output shaft, shift shaft, front seal, TCC o-ring, etc) and put a brand new Circle D 3200 278mm stall converter in it. Did the base 4l80e segment swap in the Green/Blue PCM. Put it in with brand new trans cooler lines (no kinks or restrictions) and a brand new radiator from a 1 ton 454 truck with external stock trans cooler added in front.
Took the truck for a drive yesterday and did a decent pull and next thing I notice smoke in the rearview and it wasn't rubber burning. Pulled over and it was puking trans fluid from the converter area. Towed it home and pulled trans. Front seal was blown out. Inspected everything. Pump drain and vent on top of trans were clear. Converter bushing was fine with no scoring. Bushing had not floated forward either. Torque converter snout was smooth with no wear. Put another new seal (National 4598) in it using #1 Brown Gasket Maker around the edges this time. Let it sit overnight and drove it this morning about 20-30 miles. Checked it with my inspection camera and I can see the seal pushing out again.
I have logged my drives since the swap using my VCM Scanner and the temps have been hanging 150-160* warmed up. No abnormal shifting/harsh shifting. Any ideas why this seal wants to work it's way out?
I'm pretty sure the original seal I took out was the one from the factory with 81k miles on it. It didn't push that one out prior to the swap.
Literally the only thing changed is the converter and external seals and the vehicle it's in. Any ideas?
