Do 98s have torque management?
Old Jul 6, 2004 | 04:38 PM
LS1FIRE's Avatar
Default Do 98s have torque management?
Hey yall do 98s have torque management?
98 T/A 3.23 a4.With bolt ons.
Old Jul 6, 2004 | 07:10 PM
Pete2k_Z28's Avatar
Yes, but not nearly as much as the later years, especially 01/02.
Old Jul 6, 2004 | 07:20 PM
LS1FIRE's Avatar
is it necessary to delete it? After adding 3200 to 3600 stalll?
Old Jul 7, 2004 | 12:13 AM
heyitsTaJay's Avatar
no it is not necessary to delete. i recommend not even messing with it unless you have extra money to buy a trans pretty soon. if you do anything with TM i would have it brought down to a lesser percentage, but i would steer clear of changing it.
J
Old Jul 7, 2004 | 02:06 AM
Blue2002SS's Avatar
I just installed a 3500 stall and my 1-2 shift is horrible!!! the engine compleatly cuts out for about 1 second. also it hits the rev limiter on the 2-3 shift. I am not happy because I like driving my Camaro every day but it is not fun driving like that so I am stuck driving my beater car. I am getting it tuned next month with the cam install
Old Jul 7, 2004 | 03:57 AM
Automatics's Avatar
Restricted User
Disable the TM to prevent this from happening.
Old Jul 7, 2004 | 11:53 AM
hellbents10's Avatar
LS1Tech Sponsor
You should get arid of the TM.
Old Jul 8, 2004 | 12:29 AM
LS1FIRE's Avatar
will adding a shiftkit be useless if I didnt delete my TQmanagement after installing my stall?And does shiftkits help durability?Thanks
Old Jul 8, 2004 | 01:36 AM
SmokingWS6's Avatar
My TM has been deleted but don't see why mmy trans life would be shortened all that much, it shifts exactly like stock programming except at WOT We left the trans pressure the same, lowered all shift times conservatively to .300 and left 3-4 alone(stock settings because 3-4 is weak), set the Max engine tq to 500, don't think i make that much just yet
Old Jul 10, 2004 | 05:53 PM
Pete2k_Z28's Avatar
I would delete WOT torque management only.
Old Jul 10, 2004 | 06:57 PM
jimmyblue's Avatar
Moderator
Decrease shift adaptation times to lessen
the duration of the power cut. Increase
the torque level for reduction to occur, and
change the reduction percent to suit your
preference (I currently try and limit input
torque to 400lb-ft as a compromise between
performance and protection). This affects
WOT and near-WOT but leaves most of my
part-pedal driving alone.
Old Jul 13, 2004 | 07:42 PM
highgear's Avatar
Cool
My Tuner deleted TM and left the pressure the same. He said all TM does is cut timing during the shift. Anyway, shifts better now.
Old Jul 13, 2004 | 09:26 PM
i have never heard this. can anyone else chime in and confirm this?
thanks
J
Old Jul 13, 2004 | 09:31 PM
DrkPhx's Avatar
thanks
J
Yes, it does so in a big way. It will pull 3-4 degrees of timing when the shift occurs. Now with the TM deleted it doesn't do it anymore.
Old Jul 13, 2004 | 09:34 PM
soooo...then more power is going thru the trans?
Old Jul 13, 2004 | 09:41 PM
SmokingWS6's Avatar
I was pulling up to 25 degrees of timing during shifts. untuned +23 to -4 during shift on A tap.
When people say they deleted TM, they don't mean they pushed the TM delete key and that was it. Its a series of tables you can either replace all the numbers with 0's or lessen the TM effect.
TaJay. TM controls max TQ input, reduces timing during shifts, and controls shift times.
Old Jul 13, 2004 | 09:45 PM
dam! i have A-tap. how would i be able to monitor this with my a-tap?? i wonder if im losing that much.
J
Old Jul 13, 2004 | 09:52 PM
SmokingWS6's Avatar
do a couple of runs logging the basics like TPS, RPM, Timing, KR, ect. Watch the timing drop for a split second at the same time RPM drops(shifts)
EDIT: WOT runs of course
Old Jul 14, 2004 | 04:09 PM
S_J_H's Avatar
leave TM tables alone IMO. Don't mess with shift times either as that really seems to screw things up on the 2-3.
All you have to do is work with one table. In the IGN parameters is a table called SPARK RETARD LIMIT. In the 98's it is set to -10 degrees. During a shift with TM enabled, it will pull timing back to -10 degrees which can be up to a 40 degree retard if your running 30' peak adavnce. This is how it effectively shuts off the motor.
You can adjust this figure to dial in your power during shifts. Set it at something like 24 degrees and you'll get full power shifts. Set it at 10 and it'll kill some power but not all. Adjust it until you get a shift you like. This table also effects max Knock retard so don't set it to equal your timing table. Keep it 4 to 6 degrees less than your max timing.
If your monitoring it with a scanner, the shift retard happens fast and the scanners frame update rate will not always catch it.
Steve
Old Jul 14, 2004 | 04:42 PM
SmokingWS6's Avatar
My shift times on 1-2 and 2-3 are .300, fairly conservative. I left the 3-4 shift times stock. .450 I believe. These changes are not really noticable at part throttle. If you kicking your foot around on and off the gas its a bit more responsive, other than that it just effects my WOT performace.
