What size converter for 6.0
Old Jun 18, 2018 | 05:48 AM
98 4mula's Avatar
Default What size converter for 6.0
What do you guys suggest, what do you run now? My combo is a cam motion 226/230 114+3, trick flow heads, tbss intake and long tubes in a 69 short bed F100 (3600 lbs). Rear end will have 4.10’s (29” tall tire). It’s still in the project phase so I’m buying parts as I go. It’ll be just an occasional weekend cruiser that I take to the track a couple times a year. I’m thinking a 34-3600 stall.
Old Jun 18, 2018 | 07:03 AM
MaroonMonsterLS1's Avatar
Choosing a converter is like choosing a cam. Everybody has their opinion on what's "street" and what's "race". Some people can tolerate more as a "street car" than others.
Some will tell you their 4k stall drives like a dream in city traffic...others will tell you their 2800 stall is a little doggy off the line. It all depends on what you're really trying to do, and what you're ok with calling streetable. Anythnig in the 3000-4000 stall range should work fine with that cam. Lower end being more street friendly, upper end being more speed and track friendly.
Old Jun 18, 2018 | 08:58 AM
01ssreda4's Avatar
4k circle d
Old Jun 18, 2018 | 02:59 PM
99 Black Bird T/A's Avatar
If it's a nice tight converter like Yank, anything in the 3000 to 4000 range will probably drive pretty good. My 72 vette has a Yank 3200 for the TH400 and the car drives almost like stock around town.
Old Jun 20, 2018 | 11:29 AM
98 4mula's Avatar
Someone offered a used PTC single disc w/ lockup from a turbo car. Are turbo converters and N/As built differently or should I get one specifically for my mild N/A build.
Old Jun 20, 2018 | 02:35 PM
MIKE93SVT's Avatar
4k stall is great for a weekend toy. Circle D, FTI and PTC are great choices. Have used all three.
yes, the stator is probably different for the converter spec'd for a turbo car. you'll also make significantly less power than the previous combo did and it won't flash as high.
best to get the right one for your application
Old Jul 1, 2018 | 02:55 PM
rpturbo's Avatar
I have a 3600 Yank currently. On a N/A setup, I like a larger converter. My 3600 is a little small/tight IMO for my setup. I am changing to a turbo setup, so the 4L65E and Yank will be out and the 80E PTC 3000 will be in.
