DD Converter selection help from Australia
Old Jun 20, 2018 | 09:43 PM
Aussie_LS2's Avatar
Default DD Converter selection help from Australia
So I've got a 3600lb L76 with full bolt ons, a 3.9 rear and a 4L65E - stock cam and heads (for the next 6 months) will then be a 21x/22x with 11.1 comp. I'm in Australia and theres nobody that can promise me a converter that will cut a 1.5 60ft and be able to DD.
I'm looking at a Yank or Circle D 4000rpm stall. Is this reasonable for a daily driver? I do about 30 miles a day mixed driving. I'm really unfamiliar with the torque converter companies that are Stateside so any feedback is appreciated!
Old Jun 21, 2018 | 06:17 PM
MIKE93SVT's Avatar
Circle D, FTI and PTC are all great. 4k doesn't bother me at all cruising around. It doesn't flash to 4k every time you take off. more like 1800-2300 depending on gear and weight.
Mike
Old Jun 21, 2018 | 10:36 PM
Y2K_Camaro's Avatar
Circle D makes great converters. I run a Circle D 3200 stall in my daily driven Silverado with cam/headers/4.11 gears and it drives like a dream, stalls when I need it to. I wouldn't hesitate to run the 4000 stall either. Obviously I'm not cutting a 1.5 60ft because I don't make enough power, but I'd be willing to bet the Circle D can do what you need for both a daily and track duty. Also just put a Circle D in my girlfriends LS1 swapped Silverado with heads/cam/headers. I've also heard good things about PTC, but I don't have personal experience running their converters.
Old Jun 21, 2018 | 10:49 PM
98CayenneT/A's Avatar
I cut 1.5x 60's with my yank pt4000.
with 3.90 gears it will drive very nice
Old Jun 21, 2018 | 11:10 PM
NEstyle's Avatar
My 3800 converter in a 4000 lb car with an L77 and 6l80e and 3.45s drives fine. I actually wish the converter was looser. Like the dude above said, it doesn't slip to 3800 driving normally.
Old Jun 26, 2018 | 07:29 PM
Aussie_LS2's Avatar
Just to update this I've managed to order the Circle D 3800-4000 stall. Will bump this up when it's fitted!
