T56 to 4l60e wiring harness?
In all reality you could go to a pull and pay junkyard and get the trans harness out of any f body, even a V6 as long as it uses the same color PCM as what you have. That would cost me around $15.
You'll need to get a diagram and pin the PCM plug.
I swapped my '02 from A4 to M6 a long time ago and just swapped it back a year or so ago. It's not very difficult.
And like I said you can even take the transmission wiring out of a truck or van, they will be longer but will work.
I never said it was a direct swap to use a truck or van transmission section of the harness. So it's longer. It will still work. This dude needs to leave me the hell alone.
