4l60e slipping bad
Old Jul 14, 2018 | 09:11 PM
95CamaroRevival's Avatar
Default 4l60e slipping bad
I have a 95 Camaro z28 with a 93 lt1. After we swapped out the engine the fan didn't want to turn on so we put a new fuse in for the fan then the o2 sensor started smoking so we ran a constant wire to the fan. Now i read that the o2 sensor is on the same fuse for the transmission and would cause it to go in limp mode and slip. I have changed the filter and it was clogged really bad. After the filter change the transmission shifted perfectly for a couple hundred miles now its back to slipping. There is no sign of metal shavings in the fluid but i can sometimes smell burnt fluid while driving. This is my first time owning a 4th gen and i would like some insight on whats exactly going on thank you
Old Jul 15, 2018 | 02:47 PM
performabuilt's Avatar
LS1Tech Sponsor
Sounds like the trans is done, Debris has again blocked the filter the smell is burned frictions caused by low line from clogged filter . No quick fix here you need either a rebuild or a trans and converter.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
