Transmission fluid pan torque sequence/pattern ?
Old Jul 23, 2018 | 11:01 PM
Camaro223's Avatar
Default Transmission fluid pan torque sequence/pattern ?
Is there a specific pattern to follow when tightening tranny pan bolts? Would tightening in a circle work or is a star type pattern required?
If there's a diagramdiagram, please link me i can't find any specific answer.
Any help is greatly appreciated!!
Old Jul 23, 2018 | 11:15 PM
98CayenneT/A's Avatar
I just go around in a circle a couple times and call it good with a rubber gasket
Old Jul 23, 2018 | 11:30 PM
coryforsenate's Avatar
It never hurts to do the standard 1st bolt, across, back across 1 over, etc pattern.
Old Jul 24, 2018 | 10:18 AM
Camaro223's Avatar
Is it correct to assume there's no "by the book method" ? Just don't want any leaks.
Thanks
Old Jul 24, 2018 | 11:58 AM
I think the most useful thing is a torque wrench, too tight or too loose and it'll leak. I don't know if there's an official GM service technician's method for bolting the pan back on, but there are official torque specs.
Good technique would be to alternate tightening the bolts and tightening down to the torque specifications. Can't go wrong there. But as 98CayenneT/A said, that's not "necessary".
Old Jul 24, 2018 | 09:31 PM
Camaro223's Avatar
Thanks for the input guys
