Powerglide issue
Old Aug 28, 2018 | 06:29 PM
4CamT/A's Avatar
Default Powerglide issue
Hey whats up guys... Have an issue with my glide quick run down its a stock case BTE pro brake 1.80 gearset and so on.. its a turbo car was doing some tnt and stator tube on the pump spun. So I cleaned everything out ordered a pump from FTI cleaned and flushed out trans lines and trans internals. Installed trans and now I have no high gear and reverse.. Zero oil pressure in reverse and in high gear and trans brake doesn't activate either. I only have low gear and seeing 250psi at the servo cover.. the Input shaft is a BTE single ringed shaft. I removed the trans and opened it to recheck my work. Everything looks good I air checked everything and is working no leaks. and help is appreciated
