4.8 long crank 4l80e flexplate
Old Sep 26, 2018 | 04:08 PM
Lsx Rubi's Avatar
Default 4.8 long crank 4l80e flexplate
I got a cheap 99 4.8 $200 CAD came with the harness and ECU . Came out of a manual truck and has the long crank . Wondering what flexplate would work with a 4l80e .
https://www.summitracing.com/parts/atp-z270
Has anybody had any luck with these ? Is the spacer welded onto the plate or can it be removed .
Will a th400 flex plate work ? Also I guess I would need shorter bolts as well .
Old Oct 1, 2018 | 07:25 AM
JoeNova's Avatar
Restricted User
Use the stock flat 80e flexplate.
Old Oct 1, 2018 | 01:04 PM
mjs1012's Avatar
If you want an SFI plate here is the one I have on my long crank lq4 - 93019-LSC. For a cheap stock one go with ATP z-270.
Old Oct 1, 2018 | 06:56 PM
Lsx Rubi's Avatar
Thank you for the replies . Looking for something cheap for now. Good to know the atp z270 will work , I wasn't sure since it says on summits website it won't work with a manual trans 4.8 crank . I would guess the spacer is removable in that case .
Old Oct 1, 2018 | 08:40 PM
brandon6.0's Avatar
yea just knock the spacer out and save it for a 4l80e swap with a short crank. The spacer makes up with diff between a long and short crank setup.
