1992 4l80e harness for LS
Old Oct 1, 2018 | 11:07 PM
Lsx Rubi's Avatar
Default 1992 4l80e harness for LS
I got a 92 4l80e out of a motorhome that is going behind a 4.8. So if I understand it right all I need to do change out the harness on the trans to a newer one and it should be ok ? Do I have to change out the force motor as well ? Is the newer force motor plug and play with older valve body ?
Old Oct 5, 2018 | 04:56 PM
Lsx Rubi's Avatar
Anybody ? Just need to know if I have to change the force motor or not ? If I have to ,will the the newer style force motor work ok with the 92 valve body ?Thanks .
Old Oct 5, 2018 | 05:31 PM
Jays_SSZ28's Avatar
You need to change the internal harness and changing the force motor is a good idea. I wouldn't not change the force motor.
