2005 lq4 dished flex plate
Old Oct 2, 2018 | 06:56 PM
blazzin87's Avatar
Default 2005 lq4 dished flex plate
Have a lq4 from a Yukon Denali 2005. Was originally mated to 4l65e and I would like to mate it to a 2001 4l80e. What will need to be done to accomplish this
Old Oct 2, 2018 | 07:14 PM
rpturbo's Avatar
The dished flex plate, spacer and bolts. I have a set left I think if your interested.
Old Oct 2, 2018 | 11:43 PM
blazzin87's Avatar
i have the Vortec 5.7 flex plate that the 80 was bolted to as well. It’s flat tho and has a weight on it.
Old Oct 3, 2018 | 01:09 AM
MaroonMonsterLS1's Avatar
please look at the stickies in this section. They are literally at the top of the page. I see you're a new member with this thread being your only posts.
Read the sticky. It has the correct info. Literally in the 1st post
The only response you have right now from rpturbo is incorrect. You don't want to use the dished flexplate with a spacer. This will give the incorrect spacing. Also, the dished flexplate will have the incorrect converter bolt diameter. The 4l60e torque converter and 4l80e torque converter do not share the same bolt diameter
Use the spacer with a flat flexplate for an 80e. Something from a 2500 truck with 6.0 and 4l80e is a good place to look if you want to find part numbers...but again...check the sticky and you will have all your questions spoon fed to you.
Old Oct 3, 2018 | 08:44 PM
blazzin87's Avatar
Thanks maroonMonsterLS1
Old Oct 10, 2018 | 05:21 PM
blazzin87's Avatar
Where is the sticky?
Old Oct 11, 2018 | 01:06 PM
mjs1012's Avatar
https://ls1tech.com/forums/automatic...s-spacers.html
