Newer 4l80e internals into a older 4l80e
Old Oct 2, 2018 | 08:33 PM
Crysis's Avatar
Default Newer 4l80e internals into a older 4l80e
I have this 4l80e from a 01 Silverado its fully built and the case broke I wanted to put its internals into a older 4l80e from a 93 I know the oil fittings are in different places so will I not be able to do this??
Old Oct 2, 2018 | 09:04 PM
badass68's Avatar
Too many things different.
Old Oct 2, 2018 | 09:06 PM
Crysis's Avatar
Oh ok I might look for a newer case then
Old Oct 2, 2018 | 09:09 PM
Lsx Rubi's Avatar
There are a lot of differences , you are better of rebuilding the older core , they are equally as good or find a newer style case .
https://ls1tech.com/forums/automatic-transmission/842185-late-model-4l80e-vs-early-style-differences.html
This thread has all the info you are looking for .
Old Oct 2, 2018 | 10:35 PM
MaroonMonsterLS1's Avatar
Exactly how "built" is the newer model trans?
I'm guessing the parts that are upgraded can easily be swapped.
Share with us a build list and we can check off the swappable and non-swappable parts
Old Oct 3, 2018 | 09:45 AM
badass68's Avatar
The early models have a larger overdrive roller clutch and are a little stronger anyways.
Old Oct 3, 2018 | 12:44 PM
Correct^
But even with the later model roller clutch...you need to be making some serious jam or abusing the hell out of the forward engagement before it will matter a whole lot
Old Oct 3, 2018 | 08:34 PM
Crysis's Avatar
Not sure built by someone local I can upload a pic of the parts list it cost a lot of $ and the core I have is just the case
Old Oct 3, 2018 | 08:43 PM
Jays_SSZ28's Avatar
My price on a '01 4L80E core is $40, I have three also. You should swap the case on the built trans, sell or use the older one on something else.
Old Oct 3, 2018 | 09:07 PM
Jays_SSZ28's Avatar
Also depends on what you're putting it in. If you have a range switch the '93 won't work.
