4l60e wiring question
Old Oct 12, 2018 | 03:39 PM
The0nlyon3's Avatar
Default 4l60e wiring question
Hello, little back story, have a manual VB th400 behind my 5.3 in my chevelle. I am going to a built 4l60e so I’ll have OD and won’t have to shift.
When I did the initial install, I used LT1swap.com and removed the stock transmission harness for a cleaner harness/install.
other than the 13 pin connector, are there any other sensors or wiring that I need to add or worry about?
I havent received the transmission yet or I’d just look myself.
I ended up going with a Performabuilt Level 3 and one of their billet converters.
Old Oct 12, 2018 | 04:14 PM
MaroonMonsterLS1's Avatar
speed sensor
Old Oct 12, 2018 | 05:02 PM
B52bombardier1's Avatar
Absolutely, yes above. Speed sensor. The PCM won't command a shift if it thinks the vehicle is sitting still.
Rick
Old Oct 13, 2018 | 01:38 AM
The0nlyon3's Avatar
Makes sense, okay thank you.
By Brett Foote | 2026-06-04 05:00:17
