MSD Atomic Trans Controller
Old Oct 17, 2018 | 12:49 PM
03EBZ06's Avatar
Default MSD Atomic Trans Controller
Am swapping a stick to an auto in my 2002 Z06. Going to use a 4L65E. Does this electronic device eliminate the need to swap out the pcm?
Old Oct 17, 2018 | 07:53 PM
MaroonMonsterLS1's Avatar
You would't need to swap PCM
You could change/add to the harness and use stock pcm
IMO that's what I would do...the stock pcm has better lockup strategy than any aftermarket controller I've seen (as far as lock/unlock...not TCC)
But yes, the MSD should work...also look into the US Shift.
Another option is to have the 65 built for static line pressure, and build your own (or have your builder do it) to control shifts without pcm. Full manual valve body using just the solenoids and pressure switch
