Bad tune or bad transmission?
Old Jan 3, 2019 | 11:54 AM
Caulin's Avatar
Default Bad tune or bad transmission?
Stock 4l60e behind a cammed LS2,12 bolt rearend, 3.73 gears with a spool, 3000 stall, so I took the car to get a dyno tune because it was surging and idle and getting some bad torque converter knock, tune basically made everything worse, I told the guy where I wanted it to lock and stuff, didn’t listen. Had to take it back and make him lock it at 50 now it doesn’t knock and locks up good at highway speeds. After the tune my transmission is slipping, the transmission hates WOT and basically refuses to shift between 2-3 and 3-4 when WOT it redlines like it’s in neutral when it goes to shift. Never did this before the the tune. The transmission is stock and has 100k miles. So do I take it back to him again or what do you guys think? He said I need a new tranny but I’m reluctant to listen because he also said I needed a new torque converter before I made him change the lock up. Also the car only made 288 hp which just seems wild
Old Jan 3, 2019 | 12:09 PM
bbond105's Avatar
If the trans was good before the tune, I would say the problem is with the tune. I would try to find another tuner who knows how to tune a transmission before the trans is hurt, if it's not too late already.
Old Jan 3, 2019 | 12:46 PM
Caulin's Avatar
I paid 400 bucks and he basically made my car worse, should I try and get my money back? Is that even possible with tuners?
Old Jan 3, 2019 | 12:48 PM
fst100's Avatar
most times not really. I dunno if it's a good idea for you to post the name of the tuner so any one else would steer clear from that business?
Old Jan 3, 2019 | 12:52 PM
Caulin's Avatar
that’s the thing, they’re recommended by a lot of people in my state, a few people hate them, I just feel like he kind of half assed my car and I paid the price for it. It was on a speed density tune and needed a MAF installed that’s why it surged, but he waited till after to tell me that and now that I have one in he wants to charge me again to tune it. Which I can understand but dang man, you’ve given so much trouble with this tune you can’t just help me out?
MaroonMonsterLS1's Avatar
288 horse...from a cammed LS2
he doesn't listen to what you want
he blames other parts immediately
it runs like ****
hmmm should we blame the tuner?? is that a real question? Yes you should blame the tuner. I would recommend getting it re-tuned before you actually cause damage to the trans. Banging the limiter between shifts will cause damage shortly.
Old Jan 3, 2019 | 12:53 PM
Caulin's Avatar
it runs like ****
yeah I WOT once and it did that and I haven’t touched the car since because of fear of wrecking it more
Old Jan 3, 2019 | 01:33 PM
Game ova's Avatar
OMG....288 to the tire?? That alone is enough to switch up on this so called tuner.
Old Jan 3, 2019 | 01:35 PM
That's the first thing I mentioned too. If he can't milk more than that out of a cammed LS2...I have 0 faith he can do anything right with the trans.
don't walk...run
Old Jan 3, 2019 | 11:21 PM
Caulin's Avatar
he said “because it has a 12 bolt and they take 15% of your power, and because the transmission is bad.” Honestly now that I’m typing this out I realize how dumb it is.
Old Jan 3, 2019 | 11:23 PM
Caulin's Avatar
don't walk...run
Exactly, a stock Ls2 makes what 330rwhp? And mine has a MS3 stage 3 cam, 3 inch headers, and a FAST intake.
Old Jan 4, 2019 | 04:50 AM
fst100's Avatar
if anything it ought to be +100rwhp more at around 380-390 (my brother has a ms4 A4 12 bolt that dyno'd 390 pre-AFR heads).
Old Jan 4, 2019 | 05:15 AM
handyandy496's Avatar
Smell your dip stick and if the oil looks clean, not sparkling clean with flakes of metal, take it to a tuner that's not drunk. If the new guy gets it fine go back with friends and demand your money back. Or just detune his ride home.
Old Jan 5, 2019 | 02:53 AM
Caulin's Avatar
Engine is good, checked the dipstick, checked and made sure all the cylinders are firing, checked a couple plugs and they look fine, no vacuum leaks. The motor has about 10k miles on it. Lifters are a little noisey but I heard that’s normal for cammed LS engines. It’s my daily (yeah I know, very practical) but honestly I didn’t have 400 bucks to just blow on messing up my car.
Old Jan 5, 2019 | 02:54 AM
Caulin's Avatar
yeah the car should definitely be around there. Something isn’t adding up here.
Old Jan 5, 2019 | 09:27 AM
bbond105's Avatar
I believe he was talking about your transmission dipstick.
Old Jan 6, 2019 | 04:32 PM
SlasherVRGR's Avatar
I hate to be that guy... But it says in the original post that the trans is slipping..
If the trans is slipping it's not going to post good dyno numbers. The tuner may have done his job, done it correctly and it was just too much for your trans.
Everyone is quick to blame the tuner, but no one is quick to learn to tune.. the tuner can only do so much with the hardware you present to him (your vehicle)
Old Jan 6, 2019 | 07:30 PM
Caulin's Avatar
if you’re referring to my old post about the weird noise, that ended up being the torque converter not locking at the right time. The transmission did not slip before the tune. You are correct though, the tuner isn’t a magician that can fix existing problems. That’s why it bothers me because this wasn’t an issue before.
Old Jan 6, 2019 | 07:32 PM
Caulin's Avatar
You could be right maybe the motor is making more power that’s why the trans decided now to start slipping. Thanks for the input
Old Jan 10, 2019 | 10:26 AM
performabuilt's Avatar
LS1Tech Sponsor
Tuning may be an issue however even with stock HP at 100k miles if the cars been beat on much at all I would be suspect the trans is just tired , A stock 60e is only just able to deal withstock power levels
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
