Z-Pak Clearance help
Thanks
Deuce
The specifications call for .050 - .070. I can remove the shim plate and the clearance is .070. I just didn’t know if I wanted to start out on the far end of the specifications. I’m not sure if that would lead to premature slipping.
I dont like the z pack either. Theres not enough steel to dissipate the heat. However, the clutch material is excellent. The new GPZ raybestos has the same clutch material and is the best clutch plate you can buy. The high energy clutches are good, but they are not as good as the GPZ. I have gps in my turbo car. Probably 650-700hp at the flywheel. I Do not even have a smart drum, just a reinforced stock drum, Kolene steels and 8 clutches. Never skips a beat and ive been hammering on it for about 2 years now.
