Who Vacuum tests pump and valve body on rebuild 4l60e
Does everyone here do vacuum tests on valve body and pump for 4l60e when rebuilding? Ort only if there is a specific reason to?
What about just doing wet air tests instead? Just wondering the importance of it as I don't have a proper tool to properly seal the orifices in the pump or valve body, although I do have an air compressor so could maybe do wet air tests If I know where to put fluid and what ports to seal up.
I have a write up on how to make your own vacuum tester. Less than $100 if you're crafty
I would say my rate of issues with any trans (i build alot of 60e) dropped by over 90%
Wet tests hold no candle to a proper vacuum test.
The air check shows bore wear in the valve body and to what degree it is worn. A wet air test won't do that.
Every trans that leaves my shop is vacuum tested.
