C6 drag car solenoid B stuck on second built trans.
I have an ecs supercharged 06 c6 with a 3600 circle d stall that has been giving me hell constantly. The issue is I keep loosing 4-5-6 gears and getting the code P0777 solenoid B stuck. This is my second 6l80 and this one is built with all the best parts from Corvette connection in CO. New TCM and solenoids. The car has a built ls2 and rpm stage 2 diff with 3.42 gears. The first trans was tuned by myself and I have tuned a good amount of these cars with no issues. The built trans I used the tune supplied by the builders. If anyone has any recommendations I would really appreciate it! This car is killing me. If you would like to review the tune I can send it to you.
The possibilities that I can think of are
(1) The 4-5-6 shaft sheared off (hard to believe both trans did this within 100 miles).
(2) the solenoid is actually bad (again hard to believe).
(3) Tune related.
(4) Electrical issue.
(3) Tune related.
It's funny you say that because I was just looking into that and I'm thinking that's the issue. I just did some testing and I found that with the converter unlocked at WOT it trips the code. Maybe it is seeing the input rpm is different than the output rpm due to converter slip? I did a relearn and locked the converter and so far so good. Although there is probably a reason people don't lock there converter at the track but the car feels much stronger with it locked.
LS1Tech Sponsor
__________________
Not to mention you risk slipping the lockup clutch and ruining the converter.
I would tune the trans properly rather than just lockup the converter as a bandaid
Thanks for the advice. The Trans shift speeds and pressures are set up properly. The converter pressures and lockup is most likely not. I also do not have a Dyno to properly tune the wot lockup speeds. But in most cases keeping the converter unlocked is just fine. For some reason mine just does not agree with it and it trips the code. If anyone has any advice or has experienced this I'm all ears.
LS1Tech Sponsor
__________________
