4L60E temp question
Old Jan 26, 2019 | 10:29 PM
curtisad's Avatar
Default 4L60E temp question
What temp would be considered high? In traffic during the summer my temps get to around 210. Also I have my trans cooler mounted behind my radiator. Should I re route my trans cooler in front of the radiator? Also, is the bigger the trans cooler equal cooler temps?
Old Jan 26, 2019 | 10:48 PM
2kSilverSS's Avatar
210 is high end of normal. 230-240 is getting up there and starts to harden seals and can do real damage if long term. Yes put cooler in front of radiator and bigger always helps. Giggity
Old Jan 27, 2019 | 10:47 AM
performabuilt's Avatar
LS1Tech Sponsor
210 is on the higher end of ok and yes placing the cooler on front of radiator or even remote mounting it with a fan like this
Amazon Amazon
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 27, 2019 | 10:55 AM
ironmanLS1's Avatar
Originally Posted by performabuilt
210 is on the higher end of ok and yes placing the cooler on front of radiator or even remote mounting it with a fan like this https://www.amazon.com/gp/product/B0...sX5O:rk:6:pf:0
Are you running a trans cooler in series through the radiator cooler, or only through a separate trans cooler?
Old Jan 27, 2019 | 12:20 PM
LS1Tech Sponsor
In my case the cooler is a stand alone .
__________________
Call 888-744-6542
Old Jan 27, 2019 | 03:10 PM
01ssreda4's Avatar
cooler should be in front. I think 100 over ambient temp is normal, but I prefer to be at 80 over if possible. Meaning i dont care to see 200 degrees unless its 90+ outside which with our humidity is scorching.
Old Jan 27, 2019 | 03:18 PM
98CayenneT/A's Avatar
What cooler are you running?
The cooler also can not lay flat against the radiator. Space it about a half inch.
