Shift in stall question
Old Jan 29, 2019 | 05:01 PM
shock69's Avatar
Default Shift in stall question
Ok guys new here to the 4l80e and fbody I have a 97 with the factory shifter in it. I am wanting to in stall a new B&M quarter stick. I have the right gates and hardware. The question I have is. On the side of the factory shifter there is a electronic box looks to be a gear indicator. Do I need that in the new shifter? The car is on a 2000 Silverado ECU and harness. There is only linkage on the side of the 4l80e no electronic box. Can I make the 4l80e shift through ecu with hp tunes? or if I just hook up the shifter and cable will the car still shift in drive thru the gears?
Old Jan 29, 2019 | 06:35 PM
shock69's Avatar
So the park neutral safety switch must be the black component on the side of the shifter. Now do I need to wire the park switch as well as the neutral in to the ecu?
Old Jan 29, 2019 | 09:39 PM
shock69's Avatar
Problem solved
