Transgo separator plate difference
Old Feb 1, 2019 | 06:12 AM
grasshopper645's Avatar
Default Transgo separator plate difference
97 single piece case 4l60e from a Camaro.
I have a new transgo separator plate to replace the original which is pretty stuffed.
when I compare the plates, they are identical, except for one small hole which in the transgo plate is a rectangle instead of a circle.
Does this matter? If not, does it mean I have to use the 2000 - 2002 gaskets which has the rectangle also?
Old Feb 1, 2019 | 07:05 AM
MaroonMonsterLS1's Avatar
That is for TCC regulated apply oil. The rectangle is fine. It's just a through-hole...not a metering hole.
Use it if that's the only difference
Old Feb 1, 2019 | 04:11 PM
awesome thank you! What about the gaskets? There's two distinctive gaskets in my rebuild kit. One for 97 (labled v and c)and one for 2000-2002 (labeled ca and vb) Do I need to use the 2000 style which has the rectangle ?
Old Feb 4, 2019 | 10:18 PM
PBA's Avatar
PBA
With the TransGo separator plate, always use the late gasket with the white stripe. This is for the 1993 - 2006 separator plate.Their kits come with the late gaskets, however no whits stripe on the TransGo gaskets.
