LS3 with 6R80 Transmission (Ford)
They do not bolt up without an adapter.
Why do you want to do this combo?
What will you be using to control the combo?
I personally have not seen anyone make/use this adaptor...you may have to innovate as I don't see much drive in the market for something like this (maybe I'm missing it)
Well, the 6r80 is a clutch to clutch transmission just like the 6l80 from gm. They will both have similar shift feel issues if the tune is wrong.
The 6l80e is the proper match for the LS3 and when tuned correctly, it will shift fine and last a long time.
