4L60E lost 1st and 4th (correction)
In my post #7 I wondered if the trans connector wasn't snapped in fully as it sounded to me like an electrical problem; besides the PCM I would check the trans harness to make sure it didn't melt on an exhaust pipe or got damaged in an earlier trans swap.
BTW - Even though you say "Got a rebuilt transmission and it's doing the same thing" I suspect the new trans works fine in Reverse because even if the PCM commands the lowest line pressure, the boost valve raises it significantly in Reverse.
Sorry you are still having so many problems, but your determination is making you an expert in the 4L60E with a degree from the prestigious "School of Hard Knocks". You''ll be helping others here soon.
