Need Opinions on shady mechanic
I took my car to a transmission shop that replaced my 4l60e with one of their rebuilds and they told my I could pick it up that same day. They never returned my calls and the next morning they said something was wrong and it still wont shift they think it is a bad PCM so he quoted me another $750 to buy it and flash it. I was supposed to pick it up today as that is what we agreed on last friday. He hasn't been picking up any of my calls and I just have a really uneasy feeling about him. I have already paid the $2000 in cash for the transmission and I have the receipt for that ,but tonight he sent me a text saying the PCM and flash also didn't work and he is now trying to track down a short and that he was in a motorcycle accident today which is why he didn't answer any of my calls.
I am getting very worried and have a sinking feeling I am being scammed and am ready to cut my loses and just pick up my car tomorrow and sell it as is because I've had enough of it.
So does any of this sound weird to you guys or are these actual problems that could be causing the issue. So as it stands now, New transmission, new PCM and flash, new battery and it is still not shifting into second.
Any advice would greatly help as I am going to either pick up the car tomorrow and sell it or tell him I'm not paying another dime and he needs to fix it for misdiagnosing the PCM.
You've paid him $2,000 and you've been TOLD that your transmission has been replaced, a new PCM flashed has been installed along with a new battery and its still not shifting and now he's chasing a ground? Do you know for a fact that all those have been done? And your saying the day your supposed to pick up the car he's gotten into an accident? Is that what your saying? Because if it is then I'd certainly be wanting to see what all was done to my car.
I came to his house and we ran it with my stand alone harness and it worked perfect. Told him it's the wiring. He later replaced the wiring harness and it worked fine after that. This was a misdiagnosis on his part. He later tore the old harness apart and found several bad spots.
One other time I sold a guy a '93 corvette that I built the 700R4 in it, He said that the tire guy said the transmission was bad, then the alignment guy at a different shop said the transmission needed a new pump. I told him to bring the car to me.
Somehow the TV cable un-adjusted itself. I knew right away because I had marks on it. I readjusted it and it was fine, although it would have eventually killed the trans.
My point is, people are fast to assume the problem is obvious because it's common. When it's not a common problem you're seeing what happens next - they throw parts at it and scratch their heads.
Now assuming it isn't a complete scam and your old 4L60E is sitting there, perhaps a few parts from your old trans were re-used, like the Manifold Pressure Switch, which would give that symptom.
However a customer must make this request upon initial agreement of work to be performed... there is no legal requirement after the fact.
If a customer tells the repairer later on... during or after repairs, that parts are to be saved... It may be too late and the parts maybe long gone in a dumpster that a garbage truck picked up.
After all that, I just hope everything works out well in this situation... and that no body is getting screwed!
After they did the rebuild and it didn't fix the issue...why would you trust them to do the pcm? Clearly they couldn't diagnose the problem properly the first time...
https://bar.ca.gov/Consumer/Auto_Repair_Guide.html
However in Michigan, the customer has to sign a release if they don't want the parts when the work is done and they pay. It is the default.
https://www.michigan.gov/sos/0,4670,...8691--,00.html
"Customers have the right to receive back all parts replaced, except those that must be returned to a supplier or manufacturer for warranty or rebuilding purposes, which the customer is entitled to inspect "
On a side note I'm selling this car once I get it fixed as I'm headed off to my last two years of college in the fall and need the extra money so if your in California and looking let me know.
Side note: When I originally brought my car in for the no 1-2 shift my car wasn't throwing any codes so now that it is, its probably due to whatever rebuild he did that has a bad part somewhere.
