Best Trans for The $ and What Cooler
Old Mar 19, 2019 | 04:55 PM
blk97z28's Avatar
Default Best Trans for The $ and What Cooler
As the title states.
Looking at the following companies:
- FLT
-RPM
-Performa Built
I'm sure there are other and I'm looking for suggestions, as well as what cooler I should use. I've read a lot about the Tru Cool 40K?
Planning an eventual 383 Stroker motor + AFR/AI heads + Billet Custom ground cam.
Old Mar 19, 2019 | 06:09 PM
98CayenneT/A's Avatar
If you do a google search you will get literally hundreds of threads on this subject, same with trans cooler.
Old Mar 19, 2019 | 08:25 PM
98RedBird's Avatar
Best trans... My vote goes to FLT. Chuck is great.
Best cooler... biggest you can fit. As Chuck would tell you, the key to keeping the trans happy is keeping it as cool as possible.
Old Mar 19, 2019 | 10:34 PM
qweedqwag's Avatar
I second FLT mine has worked awesome.
Old Mar 21, 2019 | 01:57 PM
mjs1012's Avatar
+1 for FLT. Had one for a while and it's been flawless. I use the same cooler setup as posted above aside from the tru-cool h7b which is the same as the b&m 70274 just costs less.
